7130 issues
chucky
04-07-2008 17:51:40
I was running the 7130 today and the PTO lever would not stay ingaged unless the tractor was at full throttle but once it was ingaged it would remain ingaged until I shut it off. I was wondering what would cause this.
This is the same tractor that the hydralics are slow on. I checked the flow controlors on the side of the tractor and everything moved fine with the levers in the cab.
Again the tractor will lift a house but it takes for ever to do it.
Thanks chucky
JayIHMan
04-08-2008 17:35:12
 Re: 7130 issues in reply to chucky, 04-07-2008 17:51:40
Try adjusting cable on pto valve if equiped, on slow hyds try capping signal line on top of hitch cover under fuel tank and see if remote flow comes back.
chucky
04-08-2008 17:48:10
 Re: 7130 issues in reply to JayIHMan, 04-08-2008 17:35:12
I don't quite understand what the signal line under the fuel tank is. If you could better describe it I would appreciate it.
All hydralic filters have been replaced and trans screen was cleaned(not much on it) so I'm kind of lost other then replacing parts.
Thanks Chucky
JayIHMan
04-10-2008 16:51:27
 Re: 7130 issues in reply to chucky, 04-08-2008 17:48:10
On the left hand side behind fuel aux tank (if equiped)you will find the hitch valve. Locate the small line that goes to large pump on right side of unit, cap off line that goes to the hitch valve. This will require a face fitting(Flat) plug to do this. Start unit and see if remote flow is regained. You also mite have had an orfice come loose in priority valve located behind remotes next to transmission. I would suggest a visit to your local Case dealer for the plug to block the signal line. Hope this helps.
Iagary
04-07-2008 19:31:16
Hows the hydraulic filter?
Gary
