Hydraulic Woes...
Charles Todd
04-07-2008 19:49:33
I have searched the archives on the subject and didn't quite find the answer I was looking for.
I got all of my hydraulics back together and installed my freshly rebuilt remote valves. The valves worked almost a good as new! Quite proud of myself for pulling that one off.
The problem reared its head when I went to unload a Mott (Alamo) 88" Flail Mower from my trailer. I had to gap the throttle wide open to raise it over the side of the trailer. I figure the Mott mower weighs 1000-1200 lb. The loader has a 3000 lb lift rating @ 1800 psi. I know the system relief is 1650 psi. When I put the load to it, the diverter valve started by-passing (squealing). I have not investigated too deep but there is a set-screw on the diverter. Should I adjust this or look deeper (relief valve)?
third party image
Sorry for being long winded, it has been a long day and my mind is racing. I have not installed a gauge in-line to see what actual psi I am delivering to the remotes, but i know it seems weak. Also the power steering can be difficult at times too... May be related?
Thanks
Ted in NE
04-08-2008 06:30:24
 Re: Hydraulic Woes... in reply to Charles Todd, 04-07-2008 19:49:33
Charles, the screw on the flowdivider you are refering to is for cold oil, below zero starting. You screw it in to open the flow divider spool to help warm it up quicker.Has nothing to do with the pressure. Their is a seperate steering relief in the flow divider. Main system has own relief. As Allan & Tractor Vet said best to put press. gauge in a remote coupler & check press. Test on a flow rater would be ideal. If you have an operators manual it will explain the purpose of the screw on the
flowdivider
mkirsch
04-08-2008 05:16:57
BTW, the gauge goes in one of the remote outlets, not "in line." If you put it in line it will read 0 PSI most of the time.
Allan In NE
04-08-2008 02:39:25
Oh, I dunno.
Sometimes the angles that one has to grab at makes all the difference in the world as to "how heavy" something is, especially as viewed from the vantage point of the loader. Seems like the heaviest loads are always when something is coming off a trailer because you're reaching across to grab it.
Still and all and like you say, if there is a problem pulling it's own steering system, something is a bit amiss for sure.
TV and I go round and round on this all the time, but on a 40/50-year-old tractor, the first thing I suspect is the pump because it is the wear point. The "wide open throttle" thing is kinda indicative of this.
However, since you say it lifts fine and then "squeals" when it stops lifting, oil is by-passing somewhere and it just sounds to me as though you've either hit the capability of your loader or the hydraulic system is certainly bottoming out, whatever the cause, be it PR valve or the pump.
I'd be for looking at the steering problem first and worrying about the loader last. Betcha one will cure the other.
Just my opinion,
Allan
third party image
the tractor vet
04-07-2008 22:21:20
Have you put a pressure gauge on the system ??? if not thats a good place to start . And i don't think that the diverter valve was doing the squeeling it would be the pressure relief . Keep in mind if you screw up and try and make the hyd's do more then they are suppose to then Hyd. pressure can injure or kill . I have seen first hand what a stuck pressure relief can do as it happened to one of my uncles tractors and it blew the whole back end out of the tractor . If a hose blows and your hand arm or any part of your body i close to that the hyd pressure will go thru you clothes and thru you skin. and son when that happens you in deep do do.
Charles Todd
04-08-2008 07:07:23
 Re: Hydraulic Woes... in reply to the tractor vet, 04-07-2008 22:21:20
I agree, safety is first with compressed fluids. I have seen first hand the damage oil under skin can cause, permanent damage.
The steering works ok until you load the tractor up then it gets to a hit or miss, hard then easy. After rebuilding the remote valves, I can raise the loader at low idle. But it lacks balls with a load. I spoke to my father and he did say that years ago he suspected the hydraulic pump was failing and that is why he "retired" it to the round baler. Now I have it and trying to fix all this worn out do-do is taking longer and longer because I am finding more and more.
Whatca think, if the pump is original and the filters are good, and I put a gauge on it and get less than 1650 psi, bad pump??? Also I have heard that you can get a 1850 psi or 2050 psi relief from an industrial that will replace the 1650 psi relief. Anyone have a part number???
Thanks guys, I can be a PITA,
Charles
