340 Utility blow-by oil bath air filter
hunter522
04-08-2008 05:36:30
I did a compression test on my tractor and all 4 cylinders are around the 120 range. When I start up my tractor I would get blow by coming thru the breather on my valve cover and then it would eventually have oil on the valve cover and motor.
I have since piped with flex pipe & pvc from my valve cover to my rear axle so I at least dont have to breathe that stink.
I noticed yesterday that when I removed my oil-air filter the smoking stopped from my valve cover? No blow by at all. I am using a non-detergent oil.
Do I need a thicker oil bath oil?
Can I take off the oil air filter & replace it with a air filter (a junk-yard run to remove a complete air filter system off a car)?
If I take off the oil air filter & replace it with a automotive type air filter, is there any chance of hurting the engine?
Will a automotive air filter give me more power?
Thanks for the help.
Charles E. McNelly
04-08-2008 18:59:46
 Re: 340 Utility blow-by oil bath air filter in reply to hunter522, 04-08-2008 05:36:30
Hi Hunter, Are you using 30wt. oil in the air cleaner? Sometimes using to light of oil will cause this. Over filling the cup will do the same. As far as using a paper type element, I have used both. Will it hurt, no. I would think it all depends on what your using the tractor for depending on the conditions. Good Luck,
Charles
