crankshaft theory question
P and R Pete
04-08-2008 13:38:14
I had to replace my crankshaft because my machinist found a crack when he magna-fluxed it. I also noticed, when they were out, that both the belt pulley and flywheel were balanced via 'drillings'. My question is whether crackshafts are balanced with those two items in place, as a trio, and whether people who are totally compulsive get this redone when they get a new-used crank. (Which I'm not)
(And which I won't)
(Unless somebody says my engine will cannonade)
(Adn then I still probably won't)
Janicholson
04-08-2008 19:37:04
 Re: crankshaft theory question in reply to P and R Pete, 04-08-2008 13:38:14
Many of the 4cylinder IH engines are ballanced only because the parts are moving in opposite directions at the same time. Two pistons up, (on the ends) and twodown (#2-3) This is intrensically ballanced, as long as the pistons, and rods are all the same WT. The aluminum pistons weigh substantially less than the cast iron (earlier) pistons. Even so, no crankshaft ballancing is required. So there is no crankshaft ballance related to the Flywheel, or Pulley. They are ballanced individually, with no regard to their effect on the crank. JimN
HAS
04-08-2008 15:02:48
They are not done as a unit. The flywheel and pulley are balanced on a mandrel.
