Farmall C hyrdraulic seals
Peter in Vermon
04-08-2008 15:33:01
1950 Farmall C: I want to replace the 3 seals on the main hydraulic pump.This is the pump that is mounted in front of the distributor body. 2 seals are round (about 5/8" dia) and one is oval (about 3"). Where can I find replacement seals? Thanks for any help.
achodges1
04-08-2008 20:42:48
 Re: Farmall C hyrdraulic seals in reply to Peter in Vermont, 04-08-2008 15:33:01
The pump repair kit from the dealership is not that expensive and includes gaskets. Different pumps had different thickness o-rings. some have metal seals on the input shaft. The large oval seal was round before it assumed the shape of the pump.
ScottyHOMEy
04-08-2008 16:16:52
If somebody can come up with the correct size for the round ones, (I.D., O.D, and thickness) you might find another source for them, but you'll probably wind up at CaseIH or an equally costly hydraulic shop for the odd-shaped one. Might as well get the other two while you're there is my thinkin'.
