1939 H Hydraulic Oil?
Tom B.
04-08-2008 16:53:09
Hi Guys. My "39 H has regular Hydraulic fluid in it despite all the articles I read saying to use SAE 30 oil. Think I need to drain and refill with 30 or leave well enough alone? Bucket works fine. Raises and holds. No problems. Why would someone switch? Also, return lines tee into where the cap should be. Someone told me to pipe the return to the bottom of the sump instead. Any opinions? Please bear with me. This is my first H. Just ordered a complete set of manuals. Love it so far!
Thanks!
Tom
gene bender
04-09-2008 04:32:30
 Re: 1939 H Hydraulic Oil? in reply to Tom B., 04-08-2008 16:53:09
Just what do you mean the return lines go into the fillercap? Your H is using the belley pump as you describe but it is not a two way system. So the cycls on your loader must be for a two way system but there would not be any oil in the cycls on the return side so you dont even need hoses there but the way you have them shouldnt cause any problems as those return lines will be dry.
mkirsch
04-09-2008 04:58:00
 Re: 1939 H Hydraulic Oil? in reply to gene bender, 04-09-2008 04:32:30
gene:
The upper ends of the cylinders are probably being used for auxiliary reservoirs. A belly pump doesn't hold enough oil to raise most one-way loaders all the way up without going dry.
This was VERY common with those old "straight arm" loaders with the really long cylinders.
As the loader is raised, oil is pushed out of the tops of the cylinders and into the belly pump through the fill pipe. When the loader is lowered, the excess oil is sucked back into the tops of the cylinders.
Tom B:
You do NOT want the return line on the bottom of the sump. Leave it where it is. Otherwise, the belly pump reservoir will never be full. Here's why:
Because the cylinder shafts are taking up some room inside the tops of the cylinders, there will never be as much oil coming in as going out as you raise the loader. If you raise the loader and refill the reservoir, the loader won't go all the way back down for the same reason.
Charlie M
04-08-2008 17:54:19
The only problem with the lighter weight oil will be if it gets hot from a lot of use then it will cause a loss of hydraulic pressure as the oil thins too much. If you system is working for what you are doing then there isn't a problem, I'd leave it the way it is.
CNKS
04-08-2008 17:10:18
The pump really doesn't care what is in it. If you are satisfied, don't change. You may see more leaks, and it may not give the pressure of 30W, but again if it works leave it alone. I don't have a loader, but I believe the reason for not using the fill opening for a return is the possibility of it squirting out the vent. Same recommendation as above.
