Farmall H serial number question.
Darrell, Jr. (M
04-08-2008 17:24:52
we have aquired a Farmall H and the model number is HX1 and the serial number is FBH 36312X1. We are not real up on the Farmall's but this doesn't sound like a normal model or seial number. Is there something special about this tractor? The tractor is in PA at my Grandfathers and will be coming back to MN, but we were just wondering about this model and serial number.
Andrew Z
04-08-2008 18:32:33
 Re: Farmall H serial number question. in reply to Darrell, Jr. (MN), 04-08-2008 17:24:52
If the suffix (numbers after the serial number)reads "X1H" then it was ordered with high Gasoline engine, high speed gears, adn 8,000 foot altitude pistions.
Andrew
CNKS
04-08-2008 17:30:50
I can't explain the HX1. FBH is the model (actually the IH notation for Farmall H) assembled in 1940. X1 means it has a gasoline (only) engine, not equipped for keosene or distillate. Suggest you read the serial tag again as regards the HX1.
