IHC V-8
:RIVIR
04-08-2008 19:15:38
wanted lots of feedback , my V-8 engine in 4568 IHC 4wd tractor is only running on 6 cylinders, it sounds like a loud diesel knock at the top of motor, both front pistons not firing,(why both front ones) cracked lines on those two injectors, fuel spurts out, no change in sound of engine, how could the two quit same time. what should i look at :~(
Hugh MacKay
04-09-2008 18:50:00
 Re: IHC V-8 in reply to :RIVIR, 04-08-2008 19:15:38
Rivir: Your description is valve lifter push rod. Been there and done that, you can hear it a mile away if directly in front of tractor. I don't have any V8 diesel experience, however it would be reasonable for a valve to affect an opposite valve.
Ken L
04-09-2008 16:24:36
I ran one of those for a couple years and I overhauled a couple of the 800s. My opinion of that engine is that it never should have gone into production. Gutless wonder, a 466 would put it to shame and, it was very expensive to repair. We had the same problem with one. IH used soft metal for the lifters and just glued a hardened disk on the bottom for the cam to run against. What happened to ours was, the glue let go on a lifter and the disc fell off. In no time, the lifter was peened over and got stuck in the bore so the valve couldn't work. I hope that is not your problem. To replace a lifter. you will have to remove the engine from the tractor and then remove the crankshaft to get to the lifter. The happiest day in my life was when we updated and got rid of those engines.
Owen Aaland
04-09-2008 11:43:37
(quoted from post at 05:28:10 04/09/08) If I remember right those engines are designed to run on 4 cylinders at idle and all 8 under load. They will cut out every other one in the firing order. I know it still does not explain your situation.
Can anyone else confirm this?
The 4586 has a DV800 engine. The DV550 is the one that runs on four cylinders at idle and partial load.
:RIVIR
04-09-2008 13:33:18
 Re: IHC V-8 in reply to Owen Aaland, 04-09-2008 11:43:37
the 4568 and the 4586 both have D V800 engines they dont run on 4 cylinders at an idle just the smaller engine do DV550. :~(
Ry
04-09-2008 05:28:10
If I remember right those engines are designed to run on 4 cylinders at idle and all 8 under load. They will cut out every other one in the firing order. I know it still does not explain your situation. Can anyone else confirm this?
Bob
04-08-2008 21:52:16
Any possibilty 2 injector lines got swapped at the pump?
the tractor vet
04-08-2008 19:38:57
Pull both valve covers and see if maybe a push rod may have broken and took one or more with it . Shooten in the dark on this one.
teddy52food
04-09-2008 06:29:21
 Re: IHC V-8 in reply to the tractor vet, 04-08-2008 19:38:57
With the valve cover off, turn it over & see if all the valves are working.
:RIVIR
04-08-2008 20:44:52
had both valve covers off, each piston has 4 valves everything working order there, so that lets cam idea out, ps. tractor starts good, but no running on all cylinders, but keep shootin in dark light may come :~(
teddy52food
04-09-2008 09:49:24
 Re: IHC V-8 in reply to :RIVIR, 04-08-2008 20:44:52
I would pull those 2 injectors and have them checked. Check the compression when you take them out.
Bob
04-08-2008 20:02:59
 Vet... in reply to the tractor vet, 04-08-2008 19:38:57
Is the cam driven from the rear on those?... I can't recall at the moment.
willL
04-10-2008 20:35:32
 Re: Vet... in reply to Bob, 04-08-2008 20:02:59
Driven from the front.
