340 pto; proper clutch adjustment
YMIfxnTractor
04-09-2008 05:52:27
I know from reading all the posts that this is a repetitious question, but my problem is, my manuel doesnt cover the clutch plate style pto. I have made a couple of attempts to dial in the correct amount of slack in the clutch stack,,,but either make it too tight to "cam" engaged, or slip. After several attempts at heaving that chunk back up on the workbench and back on without stellar results, I have decided to humble myself and ASK how.
Owen Aaland
04-09-2008 11:49:01
 Re: 340 pto; proper clutch adjustment in reply to YMIfxnTractor, 04-09-2008 05:52:27
I adjust them by clamping the output shaft in a vice to hold it solid and then adjust them so that you can just get them to go over center. Use a 2 or 3 foot length pipe on the lever as a handle.
