Farmall A Spec's
JOE SEARLES
04-09-2008 08:40:06
I have a Farmall A with a 113 eng. I need to know the timing procedure and also spec's for valve clearances and magneto settings and torque values for the head and bearing caps and etc. I am rebuilding the tractor and the manual I have does not give me this info as it is parts only
Any help would be greatly appreciated.
Thanks,
Joe
Charles E. McNelly
04-09-2008 16:36:16
 Re: Farmall A Spec's in reply to JOE SEARLES, 04-09-2008 08:40:06
Joe, the best thing I ever did when I went through my B was to buy a service manual. Can"t go wrong with the info. Try Binder Books and good luck,
Charles
JOE SEARLES
04-10-2008 04:29:36
 Re: Farmall A Spec's in reply to Charles E. McNelly, 04-09-2008 16:36:16
Thanks, Charles, it is actually for my brother. he has ordered a book but hasn't got it yet and wanted to start getting it back together. I found this website and it has been very helpful. Appreciate you comments.
Joe
Marv
04-09-2008 08:53:12
Joe, Some of the needed information can be found on this forum. Look for tune up specs which is listed under Research & Info located to the left column of this page. Good luck. Marv
