Tie Rod Ends
Farmall In Tenn
04-09-2008 11:29:02
Does anyone have the aftermarket part numbers for the tie rod ends on a Farmall 100 ? NAPA, MOOG or others. Thanks
tn terry t
04-09-2008 16:45:13
 Re: Tie Rod Ends in reply to IaGary, 04-09-2008 11:29:02
Link
punch the link above and then put your model in and you can find what you need some aftermarket use the same part numbers as farmall
Daniel H.
04-09-2008 19:30:28
 Re: Tie Rod Ends in reply to tn terry t, 04-09-2008 16:45:13
Try A&I products. You use the IH part number, but their prices are much cheaper. I try to buy from Case/IH when I can but, the long notched ones (360412R11)are around $45.00 from them and $210.00 from Case/IH. The short ones (356540R91) are $16.00 from A&I and $33.00 from Case/IH. The tubes are also available. The only problem I ran into with the A&I tubes is the narrowest setting (44") will not work with out trimming 3/8" off the long tie rod. I think it is due to the way they form the taper on the tubes. Most people don"t use the 44" tread, so it isn"t a big issue. Be aware there are two different tubes 7/8" and 1"OD, and the part numbers for the 7/8" OD are different.
