A Burns Oil Sometimes??
nyvines
04-09-2008 15:39:20
I have an "A" that has run great and has not burned oil in the past however; lately once in a while it will be running fine then all at once blue oil smoke pours out of the exhaust for a couple of minutes then it just goes away and goes back to running fine and not burning any oil. Other than this problem the tractor is a great runner and has no other problems.
I am stumped, I need to hear from the experts on this one.
DARDAN
04-10-2008 00:10:25
 Re: A Burns Oil Sometimes?? in reply to nyvines, 04-09-2008 15:39:20
Possible plugged or restricted drain back in head? If a connecting rod has a little twist in it the rings will walk around the grooves and occasionaly the end gaps of the rings will line up and smoke. Then they rotate some more and it goes away.
The older and more worn the engine, the more noticable it will become, as the end gaps on the rings gets wider.
IH2444
04-09-2008 17:09:29
a crankcase venting problem ?
nyvines
04-13-2008 13:22:01
 Re: A Burns Oil Sometimes?? in reply to IH2444, 04-09-2008 17:09:29
Thanks, I took the vent off and soaked it in solvent....it cured the problem!
Thanks Again
El Toro
04-09-2008 16:12:39
It may need new seals on the valves or new valve guides. Hal
