Farmall M trans shaft seals
onefarmer
04-09-2008 17:25:33
I'm working on my M replacing the pto, main input and hyd pump shaft seals. On the pto and hyd pump the original seal was a one piece unit that looked like three singles stacked together. What I got when ordering them was the normal modern single seal.
Should I stack two or three of them in there, or will just the single do the job?
nebraska kirk
04-09-2008 18:29:50
 Re: Farmall M trans shaft seals in reply to onefarmer, 04-09-2008 17:25:33
One seal is enough, the old original seals had a leather sealing lip while the new ones have a high quality rubber seal.
james rumph
04-09-2008 18:27:37
I used just 1 seal inbetween the ware marks on the skaft from the factory seal.
Getting to the seal can be fun, i welded a piece if 1/2 key stock to a old impact socket.
I have a real good impact gun so it came wright off , i believe it is a left hand thread.
Put it in gear when you do this to keep it from moving.
Haas
04-09-2008 17:39:37
Some folks will tell you to use two of the new seals. That is not necessary and one of the new seals will be better than the old seal ever was provided the surface that it runs on is in good condition.
