ive got a little concern about a oil pump
tn terry t
04-10-2008 19:50:02
my 230 had a oil pressure drop all of a sudden went from foury psi ,cold to less that twenty ,cold on new oil and down to nuthin when hot pulled the pan and the bottom gastet was blown out in two places . i can deal with that but this is what im not sure about there seems to be a lot of slop in the gear and long shaft i can move the gears apart quit a bit. In an exploded photo i dont see any bushing to replace to get rit of part of the slop . heck i dunno might be makin mountains out of mole hills what ya think
tn terry t
04-10-2008 20:57:13
 Re: ive got a little concern about a oil pump in reply to dej(jed), 04-10-2008 19:50:02
thanks there riverbend its a new gauge less than 3 wks old i know that dont mean anything though. gona go ahead and throw new bearings in there while i'm in there. please refresh me on how to flaten that cover iv never done it. ive heard on here about using a glass plate do you really grind the plate on the flat glass or is the glass only used as a true surface with sand paper?
riverbend
04-11-2008 08:12:31
 Re: ive got a little concern about a oil pump in reply to tn terry t, 04-10-2008 20:57:13
The glass is a flat surface for the sandpaper. I made a few light passes with 80 grit to see where the low spots were. Once they started showing marks, I switched to 320. Keep at it until the plate is a uniform color. Clean well. I torqued the bolts to 20 ft.lb.
Greg
riverbend
04-10-2008 20:36:09
 Re: ive got a little concern about a oil pump in reply to tn terry t, 04-10-2008 19:50:02
Sounds like your oil pump is worn. If you believe your oil pressure gauge and you really had 40 psi before, that's adequate. Flatten the cover and put a new gasket in it.
Greg
