Farmall H compression
stronics
04-11-2008 16:23:46
I have a H that has a miss in it that I can't seem to find whats causing it. New points, rotor, plugs, distributer cap and wires. Still misses when opening up throttle, some at other speeds too.
Compression was 75lbs. cold, warm 55, seems low to me.
Any thoughts?
Thanks for any help or suggestions,
David
gene bender
04-12-2008 11:37:57
 Re: Farmall H compression in reply to stronics, 04-11-2008 16:23:46
What is it in comparision to the other three as 55 is low.
alliswd45
04-12-2008 06:04:03
well, the timing could be off a little bit, the carb could need some adjusting, or you'll need new pistons rings.
Bob Kerr
04-11-2008 23:35:07
My H has firecrater pistons and it pressed 149-151 lbs on all 4 which was right on the money for firecraters. If I remember right the gas engine pressure PSI is about 120 and the distillate 110? or ??
Marv
04-11-2008 19:17:55
The miss might be caused by loose manifold bolts. Spray WD 40 over the manifold while the engine is running. If air is leaking past the gasket you will notice a change in engine RPM.
Steven f/AZ
04-11-2008 17:55:27
stronics, sounds like it's time to try another gauge... Good luck!
Steven f/AZ
04-11-2008 17:11:18
Compression is supposed to be higher when warm, not lower!
If there is only 55 lbs you should have a serious smoker! Or some really leaky valves...
stronics
04-11-2008 17:33:21
 Re: Farmall H compression in reply to Steven f/AZ, 04-11-2008 17:11:18
Steven,
It doesn't smoke, go figure. Number 1 has a slight trace of oil on plug but thats it.
I am really starting to suspect the gauge as to the readings, I was to believe higher reading when hot.
David
Allan In NE
04-11-2008 16:58:31
If you are sure your gauge is good, overhaul 'er.
That is lousy compression; it’s a wonder it even runs.
Allan
stronics
04-11-2008 17:09:51
 Re: Farmall H compression in reply to Allan In NE, 04-11-2008 16:58:31
Allan,
The gauge has probably seen better days, I think I'll buy a new one tomorrow just to check again. I'm surprised it runs with 55lbs too.
Thanks,
David
stronics
04-11-2008 16:48:06
I did have the throttle open, it was on all cylinders the 75 and 55. It sat for several years and has only been running for a couple hours. It's had some rough work performed on it and trying to sort it all out.
Thanks for the help,
David
teddy52food
04-11-2008 17:58:23
 Re: Farmall H compression in reply to stronics, 04-11-2008 16:48:06
If it sat for awhile, I would guess it has rusty valves and pitted seats. Can you do a leak-down test & see why the compression is so low?
Janicholson
04-11-2008 16:34:52
If the test was done with the throttle open, all plugs out, and good cranking speed, it is low. Differences in compression between cylinders is moew important than the actual numbers. If your gauge is accurate, and conditions are as above, and they are all low, I would look for signs of oil consumption. if not using oil, the misfire could be sticking valves, or a leaky intake manifold, or intake gasket, allwing one cylinder to not fire. Read the plugs, Differences may allow diagnosis. Find the offending cylinder by pulling one wire at a time then replacing it until the guilty cylinder is located. Good luck, help us by staying with this nthread. JimN
Andrew Z
04-11-2008 16:31:54
Do you have 55lbs on all the cylinders or just one? if you do then its pretty tired and should be serviced..... but prior to that i would adjust your valves and make sure that there all set properly adjusted. but its most likely both the valves and the rings are going...
Andrew
