Farmall Super C thermostat question
IHMANKY
04-12-2008 10:14:27
When putting a new thermostat in a Super C (and later model C's with thermostats), when you set the thermostat down onto the boss in the water neck, and then put the snap ring in above it, there is a pretty good gap there. I'm sure there's nothing else missing.. so I guess water pressure pushes it up against that snap ring and seals it off when running. Is this correct?
riverbend
04-12-2008 14:27:01
 Re: Farmall Super C thermostat question in reply to IHMANKY, 04-12-2008 10:14:27
I got a strip of thin brass at the hardware store, cut it to size - 5/16" X 6", and bent it to fit.
The thermostat looks like a regular automotive one.
Greg
Janicholson
04-12-2008 16:46:23
 Re: Farmall Super C thermostat question in reply to riverbend, 04-12-2008 14:27:01
Another option is to use a nice thick "O"ring to space it. JimN
Tim in NB
04-12-2008 12:52:51
There is supposed to be a spacer in there to hold the thermostat up against the snap ring. The original thermostat was a bellows type that used all of the space but when you change to an automotive type you need the spacer. You can purchase the spacer at any CaseIH dealer.
ShaggyM
04-12-2008 11:21:11
Where can you get a new Thermostat?
