FarmallSuper H Steering
Greg 2010
04-13-2008 05:27:04
I replaced the sector gear om my super H because the steering was so bad. How tight is the nut to be tigntened done. It was npt toghtened done at all when I removed it. I just twisted it off with my fingers. shouldn't it be tighter than that. Thanks for you help or suggestions.
Andrew Kappers
04-13-2008 19:13:06
 Re: FarmallSuper H Steering in reply to Greg 2010, 04-13-2008 05:27:04
When i tighten mine I use the air impact you just have to keep watching for the hole in the shaft and the castle nut to line up to push the cotter pin through
Bob M
04-13-2008 08:57:19
I've not found a torque spec for that nut. However based on the tread diameter/pitch I tightened the nut on my SH to about 90 ft-lb
Also the nut should be castellated to accept a cotter pin. After tightening turn the nut back just enough so one of the castellations lines up with the cotter pin hole in the pivot shaft, then slide a cotter pin through to lock it.
Red Mist
04-13-2008 06:22:41
Sometimes they work loose and by tightening them, you eliminate some of the play. By all means, tighten it down good and solid. mike
