IH 484 diesel fuel system.
Mike Templeton
04-13-2008 10:24:11
I have a 484 IH Diesel. The fuel line that runs between the two fuel filters is leaking in the flexible part. I talked to a Case/IH dealer and they told me that part is no longer available. I don't have a parts manual. Is there anywhere I might try to get a new fuel line that might still have parts in stock? Also, I noticed on the fuel shut-off control that it was marked RUN-START- and I believe STOP, (some is missing, the rest painted over) I never knew there was a "start" position, just stop and run- does it start better in the start position? Thanks for any info.
Tim in NB
04-13-2008 15:07:04
 Re: IH 484 diesel fuel system. in reply to Mike Templeton, 04-13-2008 10:24:11
There is a serial number break for that tube. Serial number 376419 and below uses 3218478R1. Serial number 376420 and above uses 3228065R1. You can look this up on the CaseIH web site.
Here is what the owners manual says about the fuel control lever. "This is a three position lever. Fully upward is the engine RUN position, the mid position is for START where excess fuel is metered to the engine by the injection pump to aid cold starting and fully downward is the engine STOP position."
