Hand cranking overhauled engine
chuck kaufman
04-13-2008 17:09:21
Time to start up my freshly overhauled O14 engine by hand any good tricks on this topic ? The engine is mighty stiff .Thanks Chuck K.
James Williams
04-13-2008 18:59:22
 Re: Hand cranking overhauled engine in reply to chuck kaufman, 04-13-2008 17:09:21
Chuck,I have restored several 12 &14,mostly used the old sleeves and installed new rings,Absulutly no problems,On my F14 I installed new sleeves and rings,and the motor is tight becaues of compression,It would start when you pulled it but not by hand.I installed a starter system on it and cured my problem.I later found the proper timing mark on the flywheel,and it starts very quick,The timing is critical.After working the motor a little I beleive it will loosen up some
jimmy
Tom Fleming
04-13-2008 18:39:19
why not pull start it first..... .
