Super A cultivators - fit or adaptable to a C ??
Clefus
04-13-2008 19:54:16
I know a guy that bought a Super A with cultivators and may be able to get them if they will fit our C -- or what modifications would be required...
Would the A's be single row and could I add shovels for two row corn on the C..??
I havent looked at them yet but he said it has the trailing mounts for the tire track also..
Whats a fair price....??
I have a set for my BN but they are manual lift and are missing some pieces.....
Thanks...
Clefus
04-14-2008 15:35:52
 Re: Super A cultivators - fit or adaptable to a C ?? in reply to Clefus, 04-13-2008 19:54:16
Randy....Western Pa ...little too far but thanks anyways....
Gene ... If I get some stuff done the next few weeks I will get the BN out and put them on and see what I need ....I parked the BN last fall ...needs a fuel line / carb cleaning and/or rebuild..not sure yet...either dirt in line or float/needle problem....runs fine then will act like it runs out of gas....I'll get it figured out...
I have a pump to add to the BN for hydraulics...but need to figure out where to stick it...already have a delco alternator replacing the generator....I want to make the cults hydr. lift
Thanks..
Randy in NE
04-14-2008 04:46:01
Where are you located. I have a set for a C/Super C that I would let go. You would proably spend more in fuel to get them than you would pay for them. They are in NE Nebraska.
gene bender
04-13-2008 23:54:06
One quick look and you will see there just isnt any way to make them fit but mite have the missing pieces for the BN. You said you need some pieces do you know which ones you are missing as i mite have them.
Don L C
04-13-2008 20:38:36
Clfus ---
No way should you buy those A cultivators and try to make them fit your C ...Get away from that guy, he is trying to dump them on you..no..no way..
They are one row and the C, has a two row cultivator...not even close to being the same....
Look around you will find a set for your C...they fit well and are great cultivators...
..... good luck.....Don
Janicholson
04-13-2008 20:09:04
Though modification is possible, it would require heroic effort to make the system operational. Trading for C apparatus is far more productive. JimN
