140/Super A Manifold
Vacherie
04-14-2008 04:08:44
Will a Super A manifold work on a 140?
BIGFUTTY
04-14-2008 07:33:27
 Re: 140/Super A Manifold in reply to Vacherie, 04-14-2008 04:08:44
I dont know about a super a but i know that a super c has the same engine so it will bolt right up and work
Glynn Moore
04-14-2008 05:49:59
Tried it once and found that the breather stack
would not match up-- Think there's also a problem
with the govenor rod--Also found the carbs would
not interchange because of difference in width of
mounting holes on manifolds/carbs--Glynn
Vacherie
04-14-2008 06:50:48
 Re: 140/Super A Manifold in reply to Glynn Moore, 04-14-2008 05:49:59
Thanks. I will get one specifically for the 140.
Glynn Moore
04-14-2008 09:39:01
 Re: 140/Super A Manifold in reply to Vacherie, 04-14-2008 06:50:48
The 100,130, and 140 are interchangable--I have
swapped 100 to 140 and visa versa without any
notable problems---I have a 100 parts tractor,
but I am in South Geargia--good luck--Glynn
