Hyd Pump woes,
farmall kirk,
04-14-2008 05:37:08
mannn O mannn those hyd hoses are a total butt to get off, i mean ive never seen anything so hard to get off and stubborn,
I put wd-40 on there all over and still they are so stubborn that its rediculous,
maybe ill have to get a big crecent, or a big wrench and just put all my weight on it, and then it will give,
I got the distributor off and didnt touch the timing cam on it,
Buttt,,,, If i can get that pump off then ill be doing good,
Is there a couple of bolts behind the housing as I cant get the thing off and the pump housing off from the backing plate, whew,
glennster
04-14-2008 05:43:57
 Re: Hyd Pump woes, in reply to farmall kirk,, 04-14-2008 05:37:08
kirk, the live pump is held on to the front cover with 4 bolts, two on the outside of the pump and two on the engine side. remove them and the pump should slide right out. it may stick a little on the gasket.
farmall kirk,
04-14-2008 05:54:43
 Re: Hyd Pump woes, in reply to glennster, 04-14-2008 05:43:57
Hi glennster,
its kirk,
i hada feeling it was the one's next to the engine , as thats the ones i couldnt get too or had to really look for them, and then find a way to get at them,
Ill go out there and try again and maybe this time???
Ill get that thing off,
