Farmall F-20 belt speed
Rick in MD
04-14-2008 15:36:19
I would like to find an F-20 some day and was wondering is there enough belt speed to run an enslidge (spelling) cutter and be able to blow silage up into a silo? Also can I run a thresher?
LenNH
04-16-2008 16:13:33
 Re: Farmall F-20 belt speed in reply to Rick in MD, 04-14-2008 15:36:19
As to ensilage blower, it may depend on size. Don't know much about the modern blowers that don't chop. My father had a Blizzard ensilage CHOPPER, which also had paddles on the flywheel to blow corn up into the silo. Our 10-20 ran this just fine. I'd have to assume the seller of the chopper knew what size to send out for a particular amount of h.p. An F-20 and a 10-20 were meant to pull the same loads.
Nebraska Cowman
04-15-2008 06:56:24
Belt speed is measured in feet per minute (FPM) So yes, by changing pulleys you can get any speed you want.
LenNH
04-14-2008 16:40:18
I have an original IHC sales brochure for F-20.
Belt speed is 2610 feet-per-minute from a 15-1/4
inch diameter pulley turning at 654 rpm. The brochure states 28 hp, but does not state the fuel. The Nebraska tests always used kerosene or distillate, so we can assume that. This brochure is from 1938. The "rated" belt hp is shown as 85% of maximum at 23.80 hp.
Rated hp was always used as a guide to a reasonable load. Use of a bigger load than the "rated load" could result in overloading the tractor if the going got tough.
An older brochure (no date, but I would guess about 1935, lists the pulley as 14" in diameter, and belt speed of 2395 feet per minute at 645 rpm. This brochure does not give horsepower but states that the "rated" belt horsepower will drive a 22-inch thresher.
All rpms are at 1200 rpm full-load governed speed.
When I was growing up on the farm in the 40s, we used both a 10-20 and an F-20 to operate our 22" thresher, and both tractors handled the load with
no problems.
There were bigger threshers. The older of these brochures puts a 28-inch thresher with the F-30.
F-Dean
04-14-2008 16:30:02
A F-20 will run the thresher fine (That's what Dad did with his), but you would need a F-30 or W-30 to run the enslidge blower
TractormanNC
04-14-2008 15:57:20
Thresher, you will probably be ok. An ensilage cutter will WORK a good M.
HAS
04-14-2008 16:11:30
 Re: Farmall F-20 belt speed in reply to TractormanNC, 04-14-2008 15:57:20
I agree - it'll do the thresher fine.
