Order Farmall Cub Parts Online
cub hyd. pump
ira biggs
04-14-2008 17:23:44
is it possible for the seal on the hyd. pump to leak into the crankcase , if so is the seal hard to replace? thanks for any help
El Toro
04-15-2008 03:46:18
 Re: cub hyd. pump in reply to ira biggs, 04-14-2008 17:23:44
You may need a speedi sleeve if the old seal has worn a groove into the surface of that shaft. Hal
gene
04-14-2008 17:53:46
Yes. Common occurance for the hydraulic pump to go bad and leak into the crankcase.
There are two different hydraulic pumps for the Cub. Repair kits are available at Case/IH dealers.
One of the pumps requires the front seal to be purchased seperately from the repair kit.
