CORRECT GAUGES?
HARLEY EAVES
04-14-2008 17:50:53
STARTED PUTTING THE 1939 M BACK TOGETHER. I WOULD LIKE TO KEEP IT AS ORIGNAL AS POSSIBLE, SO I NEED TO KNOW WHAT THE ORIGNAL OIL, TEMPERATURE AND AMMETER GAUGES HAD ON THE FACE (I.E., IH, IHC ETC). THE ONES THAT WERE ON IT HAVE EITHER TURNED SO DARK OR RUSTED TO WHERE YOU CAN NOT TELL. I CAN NOT FIND A PART NO ON ANY OF THEM. ANY HELP WOULD BE APPRECIATED. SURE I WILL HAVE MORE QUESTIONS AS I PROGRESS.
HARLEY
GordoSD
04-15-2008 06:15:19
 Re: CORRECT GAUGES? in reply to HARLEY EAVES, 04-14-2008 17:50:53
Valu-Built is about 25% cheaper across the board on IH parts.
GW
Harley Eaves
04-15-2008 06:07:08
Thanks for the suggestions, even the negative comments on my typing style. At my age, I just thank GOD that I am able to operate this machine at all. Yes I have a catalog that list several different gauges is why I was concerned of which one to purchase. I will try OEM and compare to this site.
mkirsch
04-15-2008 06:21:05
 Re: CORRECT GAUGES? in reply to Harley Eaves, 04-15-2008 06:07:08
OEM lists which gauges are correct for which years. Even if you don't buy from OEM, it's a good reference.
Contrary to what gene bender says, do worry about the all caps. You're from that generation where being polite still counts, and there is no excuse for being impolite, right? Part of being polite to others while online is not posting in all caps.
brainerd dave
04-15-2008 09:13:44
 Re: CORRECT GAUGES? in reply to mkirsch, 04-15-2008 06:21:05
Had a sales guy that always typed in caps and tried for a year to get him to stop. I finally found out that his eyesight was so bad that it was the only way he could see what he was typing.
Part of being from the polite generation as well.
It's only impolite if you look at it that way.
gene bender
04-15-2008 02:52:34
Dont worry about the caps. Do you have any listings for the guages as there are several types available.
Mike CA
04-14-2008 20:37:18
I read all caps like the fellow is yelling. :lol:
Yeah, I find it a bit annoying as well.
but the IHC gauges are correct. OEM sells them as a set.
skk-bg red fan
04-14-2008 19:56:05
OEM tractor has the correct replacement gauges, still made by Rochester, if memory serves me right. -- I'm willing to bet they and IH are exactly the same item now regardless whom you order from.
The only complaint I have ever heard is that the new units may not be calibrated as accurately (for the tractor) as the old originals were.
charles todd
04-14-2008 19:47:52
 Re: CORRECT GAUGES? in reply to Janicholson, 04-14-2008 17:50:53
EBAY, many repro gauges.
kfox
04-14-2008 19:15:57
The early model gauges had the IHC logo, and the rims were black instead of chrome. I think every thing but the class lens was painted red, so maybe that wouldnt matter. ken
CNKS
04-14-2008 17:56:17
 Re: CORRECT GAUGES? in reply to CNKS, 04-14-2008 17:55:24
And turn off your caps key -- makes your post harder to read.
Vacherie
04-14-2008 18:43:59
 Re: CORRECT GAUGES? in reply to CNKS, 04-14-2008 17:56:17
Speak for yourself. It makes easier reading for me.
CNKS
04-15-2008 17:40:42
 Re: CORRECT GAUGES? in reply to Vacherie, 04-14-2008 18:43:59
I did -- and I'm 70 years old--a member of the "polite" generation. I wear trifocals, and someday will have to have cataracs (sp) removed. You can also change the print size on this site.
Vacherie
04-15-2008 17:49:41
 Re: CORRECT GAUGES? in reply to CNKS, 04-15-2008 17:40:42
Thanks for the information. I thought you were just being the "CORRECT POLICE". PS-I am also 70 and have enjoyed your past posts.
