1066 Flywheel
ihdoug
04-15-2008 17:40:41
Split the 10 today to put new clutch in. Wondering if you are supposed to grind the flywheel with each new clutch or not. Flywheel looks smooth and has no ridges. Also, going to replace rear motor seal and transmission seal. Supposed to do IPTO Shaft also, correct? Any thing else while were in there? Thanks Guys.
ihdoug
04-16-2008 01:54:04
 Re: 1066 Flywheel in reply to ihdoug, 04-15-2008 17:40:41
thanks again!
LBSMJS
04-15-2008 20:31:15
Definitly grind the flywheel.Around the outside dia. it wears in with a rounded edge.Look at the new disc & you will see that the edge of it is sguare.With the ceramic disc it will take for ever to wear in & will make it shift terribly.Just my experiance.
Edpap
04-15-2008 18:12:56
Hello,
sounds like you have everything covered. The flywheel step should be 1.938" if is not within .020 I would have it ground. I would replace the ipto shaft if the splines are worn. I always replace the ipto bearing and seals.check the ipto housing if the bearing turns in the housing replace the housing this is important if you do alot of heavy pto work. before you install the clutch take the clutch disc and slide it on the clutch shaft make sure is free if it binds you will have trouble going into gear until clutch wears in. check the throw out bearing carrier and pack the grove inside with grease.
Good luck Ed
Wisconsin Cowman
04-15-2008 18:03:04
It would not hurt to get the flywheel cleaned up by a machine shop.
