Where to get 00 battery cable for 350 utility?
mickey350
04-15-2008 21:44:56
Anyone know an online store that sells a 00 batery cable for a 350 utility?
El Toro
04-16-2008 06:05:40
 Re: Where to get 00 battery cable for 350 utility? in reply to mickey350, 04-15-2008 21:44:56
If there's a repair shop near you that repairs truck tractors they will have 00 battery cables. Take the old cables along for length. Hal
PS: They're easy to make yourself. Used heavy welding cables work fine.
bermuda ken
04-16-2008 05:46:47
If you need 00 cables made.....ring me toll free 1-866-FARMALL They can be easily made and will have the exact "fit" too!
gene bender
04-16-2008 05:06:45
Assembled 1 ga will work ok they shouldnt be that hard to find as they have been used for yrs on tractors with bigger engines that what a 350 utility has. NAPA and other auto store can get them if they arent in stock.
PaulW_NJ
04-16-2008 04:15:28
I've bought mine at McMaster Carr (McMaster.com), as well as solder filled lugs and terminals.
mkirsch
04-16-2008 04:59:06
 Re: Where to get 00 battery cable for 350 utility? in reply to PaulW_NJ, 04-16-2008 04:15:28
It sounds like mickey wants one pre-made, guys. Like Hugh says, it ain't gonna happen.
mickey, this is something you're best off going to a brick-n-mortar, "meatspace" store instead of online. If you take the cable with you, it's likely that you can have a new one made to your exact specifications. Worst case you get the pieces, and put it together yourself.
Michigan Tom
04-16-2008 03:36:23
Welding shops that sell supplies will have 0 and 00 cables that you can cut to proper length and add ends. Tom
GooseCreek Farms
04-16-2008 02:39:27
Just baught a "1" gauge at CarQuest to replace the old (4 gauge??) cable on my backhoe. I couldn't believe the difference it made as far as the speed and cranking power. It cost me around $24 for a 42 inch cable.
Hugh MacKay
04-16-2008 02:23:16
Mickey: The best place to find 00 gauge battery cable is shops that sell parts to the heavy trucking industry. They will sell it to you cut to your length and most will install ends.
If you looking for cables made up to 350 specs, you'll be looking a long time. Just not done that way anymore with heavy cable.
