826 International please help
USED to run Dee
04-15-2008 21:52:05
I am new to IHC and was wondering how big of disk, cultivator, and chisel plow could a good 826 pull? thank in advance
Jim Allen
04-17-2008 05:27:34
 Re: 826 International please help in reply to USED to run Deere, 04-15-2008 21:52:05
We have some pretty nasty clay here in NW Ohio and my 826 will sometimes pull a mounted 9 shank chisel, but I would hit those "spots" where it would practically stop and spin tires (even with diff lock). That or I had to adjust the draft control and ended up with inconsistent depths. I reconfigured it for 8 shanks and now it will pull almost everywhere to about 8 inches with the draft control maxed. Never tried a pull-behind chisel but I guess you'd need to be weighted down pretty good to pull a 9-shank. They say a disc chisel pulls a little easier but my neighbor's 8020 works pretty hard pulling a 9-shank disc chisel, with lots of weight and duals no less.
the tractor vet
04-16-2008 05:13:58
Well this all depends on soil type of chisel and points. Are you going to get down into the subsoil or just scratch around on top. With pulling a disc around here with out killing the tractor and with duals on 13.6 for the disc and 14-15 on a field culivartor .On the chisel 3-7 like i said before Soil type chisel style and points style and weight on the nose .And just how far down is the hard pan layer . One thing for sure ya don't have enough ponys for a 3 shank DMI with tiger points.
TractormanNC
04-16-2008 05:03:09
7 to 9 shanks depending upon soil and how deep you want to plow. In our North Carolina clay 9 shanks is ALL an 856 wants and it has a few more ponies than an 826. Push the lever down far enough and a chisel plow will stop any of them!
Allan In NE
04-16-2008 03:27:33
Should handle 15' on the field cultivator and disc.
Can't help ya on the chisel.
Allan
