140 running away
KEITH SHAW
04-16-2008 18:01:42
On my 140 when you crank it up it will idel slow but when you run it for a few minutes at half throttel and idel it back it wont come back to a slow idel , so when i try to shut it down it wants to disel are there a adjustment on the governor to slow it down ? i backed off on the timming didn't help keith
KEITH SHAW
04-18-2008 11:06:25
 Re: 140 running away in reply to KEITH SHAW, 04-16-2008 18:01:42
thanks for the information i will ch this out and let uall know keith
teddy52food
04-17-2008 06:02:08
Does it idle down when you pull ahead on the carb rod? If it does it is in the gov. If not, take the carb off & check the throttle screws. They may be loose.
Red Mist
04-17-2008 10:30:37
 Re: 140 running away in reply to teddy52food, 04-17-2008 06:02:08
teddy52food said: (quoted from post at 06:02:08 04/17/08) Does it idle down when you pull ahead on the carb rod? If it does it is in the gov. If not, take the carb off & check the throttle screws. They may be loose.
And, if it is the carb, it sounds like a very lean condition - either an air leak or a partial fuel blockage. mike
tn terry t
04-17-2008 05:53:55
 Re: 140 running away in reply to Farmallgray, 04-16-2008 18:01:42
I would like to add just a little to Brownie 450's post if ya dont mind
while your checking that throttle rod take it loose at the clevis and hold the carb closed and set the gov arm to idle with the steering mounted throttle to check that the clevis is adjusted right if its not real close it will cause your problems. I think it was Rustyfarmall who taught me this trick to cure my A it was doing the very same thing you are talking about
Brownie450
04-17-2008 04:23:36
With the engine not running, try moving the governor to carb throttle rod by hand & see if there is roughness or binding. Our A had rusted/ rough needle bearings in the governor which caused the same problem you are describing. Also, if you have the governor off, check for wear on all areas of the inside especially where the spring is attached.
