steering ram slop on 574
Jeef
04-16-2008 18:16:45
Do they make a bushing for the 574 steering ram? My steering is a bit sloppy, the ram pins sem to have some play in them. Looks like there is enough slop that it needs repaired. Tie rod ends are also getting loose.
airdefender
04-22-2008 18:18:52
 574 1976 in reply to Jeef, 04-16-2008 18:16:45
I"m looking at picking up a 574 gas 1976 and I"m told it is hydrosatic, but can"t find anything stating that. Do you now if they mad the 76 in hydro?
Jeef
04-17-2008 03:20:46
 Re: steering ram slop on 574 in reply to edward_m, 04-16-2008 18:16:45
Bob said: (quoted from post at 03:04:55 04/17/08) Go to cnh.com, and drill down through the menus 'til you get to "parts lookup", and then enter the model #, and have a look.
Looks like there is a bushing top and bottom. I will have to try to find a local dealer, We don't have much here. I want to change the tie rod ends at the same time. Mine are loser than they should be.
Bob
04-16-2008 19:04:55
 Re: steering ram slop on 574 in reply to Jeef, 04-16-2008 18:16:45
