F30 After Market Manifold
James Williams
04-17-2008 09:33:47
I just purchased a Stiner manifold for my F30,But Im not sure of a few things.My head has sleeves in the Intake ports that stick out about 1/2 in.They go into the head about 3inches,and are very tight.Do I remove them from the head or do I have them cut and plained down flush with the head.My machinest said plaining them off would be the best,Please give me your opinions
jimmy
F-Dean
04-17-2008 14:08:14
 Re: F30 After Market Manifold in reply to James Williams, 04-17-2008 09:33:47
Just pull them out. One of my F-20s has them as part of the all-fuel manifold. I believe they are to help transfer more heat to the distilate vapor. You should not need them if you use gasoline.
Fred Milner
04-17-2008 13:07:40
Just leave the them out. Next you will see that the studs are too long, just take a die and thread them all the way down and that will take care of it. I just put an after market manifold on my F 30 and that was the problems that I had. It runs good with the new one on it. The old one was all fuel and the new one is Gas.
Nebraska Cowman
04-17-2008 10:22:36
Probably. If you already have the head off anyway. But I wouldn't take it off just for that. I'd saw them off with a hacksaw or chisel them out, whatever. I doubt you will notice a difference in running. I think they were probably more to prevent leakage than anything else.
