How do you Guys check ball bearings
r4etired
04-17-2008 14:54:27
What method do you Guys use to determine if a ball bearing is usable or a throw away, Such as a pinion bearing,
mark
04-17-2008 19:51:50
 Re: How do you Guys check ball bearings in reply to r4etired, 04-17-2008 14:54:27
I give"em a good swift kick and if they double up and scream.....I figure they"re good. If they don"t do anything, they"ve gone numb and need replacing.
DCW
04-17-2008 18:41:39
Hold the bearing up to a good light source,look at the inside cone that the rollers run on,look at the rollers themselves,and how loose the outside of the bearing is.
tractorsam
04-17-2008 16:49:47
Also feel, does it roll smoothly, is it excessively loose. What state is the cage in. If it is a tapered roller bearing the recesses on the end of the rolling elements can indicate wear. tractorsam
Dave_Id
04-17-2008 16:24:41
Visual, look for any pitting.
