SA restoration update
Greg-N-CA
04-19-2008 06:07:26
third party image
We're making progress! We cleaned, washed with metal prep, solvent, and primed the tractor and sub-assemblies yesterday. Today we'll sand and shoot it with a sealer and then we'll be ready to put some red on her.
Mike CA
04-19-2008 17:56:18
 Re: SA restoration update in reply to Greg-N-CA, 04-19-2008 06:07:26
That looks like a real nice prep job Greg! Can't wait to see it all finished up!
NDS
04-19-2008 17:43:35
Looks great, it sure was not preped that good before Farmall Works put the Red paint on.
Hugh MacKay
04-19-2008 17:12:22
Greg: Looking good, great progress since the last time I saw A photo. I see you have the pto lever installed. I didn't have when I was at that stage, you guessed it, when all done my pto lever was not installed or painted. Turned out a different shade, but at least it's not very prominant.
CNKS
04-19-2008 13:10:58
If you are using primer and paint from the same company, you usually do not need a sealer, unless the instructions say so.
P and R Pete
04-19-2008 08:03:29
Sweet, buddy!
Keep the pics coming!
Mark-IA
04-19-2008 07:17:21
I see no reason to use sealer on that. Just scuff the primer with a Scotch Brite pad Blow it off and use a tack rag. Paint.
Greg-N-CA
04-19-2008 07:30:25
 Re: SA restoration update in reply to Mark-IA, 04-19-2008 07:17:21
Mark, perhaps you're right. An auto body man recommended using a sealer, but maybe that's a step that I shouldn't worry about for this application. It would save a lot of time and $s.
CNKS
04-19-2008 13:15:32
 Re: SA restoration update in reply to Greg-N-CA, 04-19-2008 07:30:25
Sealers have kind of fallen out of favor with "modern" paints. Acrylic laquer, which you are not using, sometimes required one. Certain DuPont processes still recommend one. Although sealer goes on easily, it is just one more place to mess up. What kind of primer is that -- if it happens to be epoxy, it is non-sandable. Has to be scuffed and reapplied if outside the window.
big red 1
04-19-2008 06:34:35
Nice progress.Its really gets me motivated when the paint can get put on.
Randy In Iowa
