Engine problems
Dan C
04-19-2008 14:17:06
International 2400B series
Engine has no power, now will not start. Starter engages but will not turn over engine. New battery. Could the starter be shot?
Valve cover gasket is shot, I am replacing.
Do you know what type oil should be used in this engine?
Dan
Janicholson
04-19-2008 15:22:48
 Re: Engine problems in reply to Dan C, 04-19-2008 14:17:06
Loosen the starter motor on the mounting bolts, the wiggle it if it clicks while doi n this, it was jamed. The solution is a new starter drive fro caseih. The proper one is a clutch drive. different than original. Good luck JimN
DCW
04-19-2008 14:33:23
Are you able to turn the engine over by hand?
