966 IH HDY assist spring presure
Jim Kreis
04-19-2008 16:07:51
can"t get the throw out bearing to stop turning there is presure on the clucth shaft the throw out bearing rest on the end of the ipto shaft linkage is adj up all the way could it be in the hdy assist not leting the spring presure to transfer to the other end of the hdy assist clucth pedal side need about 1 more 1 clearance to have gap in between trow out and fingers thank you
Jim Kreis
04-19-2008 21:06:01
 Re: 966 IH HDY assist spring presure in reply to Jim Kreis, 04-19-2008 16:07:51
hi had the flywheel ground down step . had rechecked thee place were work was done said had wrong clutch it was from agparts they said it was 2 thick they rebuilt old 1 but it made things
go down hill fingers stick out more so put thicker one back in they lay even with the flywhell the bolts our sticking out of fingers some what more . the throw out bearing comes out to the end of the ipto bearing cage you can push it back bye hand but it has presure from spring hdy assist forks i think can only go in one way be i will double check them thank you Jim
Edpap
04-20-2008 07:10:00
 Re: 966 IH HDY assist spring presure in reply to Jim Kreis, 04-19-2008 21:06:01
Jim,
I install about 25 clutches a year from Agparts and I have no problems. there are two different clutch's for a 966. you should of used a #405301 ppa with a #104493 4 pad disc or a #104494 6 pad. to get back to that lincage. I can't seem to find it in a book but if remember right the clutch boster spring should push the pedal up to the stop. with the front rod unhooked from the throw out bearing you should adjust the rear rod so the pin will will be free in the clutch pedal when it is up against the upper pedal stop. at this point you should have atleast an inch of thread showing on the lower adjustment with 5/8" free play. if not then either the cluch is wrong or maybe at some point some one changed the lingage rods or did some custom modifications to to the lincage instead of fixing the clutch.the only way I can think of to check this would be to find another 966 and mesure the rods.
Ed
Jim Kreis
04-20-2008 15:15:04
 Re: 966 IH HDY assist spring presure in reply to Edpap, 04-20-2008 07:10:00
hi thank you all for helping me with this ithink ed you are right about the lincage the front needs about to be shorter about 2in we have a dariyman we sell wheat to that has the same trator but he my not have the assist but it wont hurt to look at. My dad got it with 500 hrs on no one has changed it but it could be this way from fatory put new clucth in 10 years ago ?nothing more was done never ckecked the to see if it was turning then but this time it was toast the bearing was bad fingers were bad to no bearings left it. is snowing here 3in in Coville WA .not the norm this time a year keeps this up no worrys on geting trator have ford 9Nto plow snow ha thanks agian have a good after noon to all Jim....
Edpap
04-19-2008 19:40:45
Jim,
Chuck is right you need to adjust on the front side of the cyl. if you are ajusted up short with a new clutch something else is wrong. the flywheel step should be 1.406 the clutch fingers should be straight or parellel to the flywheel. I can't remember if it is possible but maybe the throw out bearing fork is on backwards.
Maybe you have a bad clutch I had some problems with Hi Cap clutches. Let me know how you make out Ed
Jim Kreis
04-19-2008 20:00:34
 Re: 966 IH HDY assist spring presure in reply to Edpap, 04-19-2008 19:40:45
thank you had the flywhell turned had them check it again got parts from agparts. clucth place said the clucth was to thick rebuilt old one tryed it did not word fingers were out to far put back in the one from agparts they are in line with flywhell with all the linkage backed off the throw out bearing is out even with the ipto shaft that the bearing is on the bolts on the fingers do stick out a 1/4 in more then the fingers acoss i cant see how the forks could go in any other way iam open to any ideas thank you Jim
Kevin Meier
04-20-2008 05:49:51
 Re: 966 IH HDY assist spring presure in reply to Jim Kreis, 04-19-2008 20:00:34
If you got the clutch from ag parts in Humboldt Iowa call ag parts and ask for Ted. He"s a great tech man.
Kevin
Edpap
04-19-2008 18:04:08
Hello,
It could be your clutch is shot. as the clutch wears the fingers come out. If you have the adjustment all the way in and you have no free play chances are your clutch is shot. Ed
Jim Kreis
04-19-2008 18:50:01
 Re: 966 IH HDY assist spring presure in reply to Edpap, 04-19-2008 18:04:08
just put new clucth in had the flywhell tunred step down new presure plate it is like the front likeage is to long
Jim Kreis
04-19-2008 18:49:53
Jim Kreis
04-19-2008 18:49:45
Chuck's Repair
04-19-2008 17:46:41
Make sure that you adjust the clutch linkage on the front side of the hydraulic cylinder and not the back.
Chuck
