My latest acquistition--560 Gas
Chris NW Ind
04-19-2008 17:11:32
third party image
Just picked this 560 gasser at an auction today in Northwest Indiana. Pretty nice, couldn't let it go for so cheap. Two problems with it, and they may be related. Power steering doesn't work, and the front end shimmies badly driving down the road. I'm also not convinced the hydraulics work, but I'll figure that out soon enough.
Serial is 45661 S-Y-CC
I take it this means TA and 540 IPTO, Hydra-touch low and reverse attachment (what is this exactly), and 3rd speed heavy duty tillage gear.
Interesting stuff I think. What do you think?
Chris B.
Chris NW Ind
04-19-2008 19:51:22
 Re: My latest acquistition--560 Gas in reply to Chris NW Ind, 04-19-2008 17:11:32
Well, to start out with I have a pair of new front tires. I'll see if that helps with the shimmy. The IPL shows the steering shaft to be mounted with tapered bearings, so it ought to be adjustable. Beyond that, I that fixing the power steering will help greatly.
I still have a 450 Gas that I just brought home needs a little tuning up. Sounds like an old 2-cylinder right now.
Chris B.
GA Dave
04-19-2008 19:26:50
Good looker. But just a grown up 240. David.
GA Dave
04-19-2008 19:39:52
 Re: My latest acquistition--560 Gas in reply to GA Dave, 04-19-2008 19:26:50
BTW. The CaseIH online catalog has exploded diagrams and part numbers you can print out should you need to. David..... Link
Fredd
04-19-2008 18:54:49
Nice piece! I have one exactly the same, and I like the slow third gear. Can't say I have ever had problems with the front end shimmying...good luck, I would like to know the solution though, should I ever have the problem arise.
Armand Tatro
04-19-2008 18:10:55
On 460 and 560 P.S. pump is mounted to the back of the main HYD. pump. Not sure about 660. My front shimmies also so I would like what you find out. Armand
tn terry t
04-19-2008 17:41:39
 Re: My latest acquistition--560 Gas in reply to ScottyHOMEy, 04-19-2008 17:11:32
isnt the steering on its own pump? i cant remember im no help to ya but i just wanted to say thats a nice ole bird you have. i would be very proud of it :D
Chris NW Ind
04-19-2008 17:12:52
third party image
Another photo....
garytomaszewski
04-19-2008 18:50:10
 Re: My latest acquistition--560 Gas in reply to Chris NW Ind, 04-19-2008 17:12:52
So you own stock in Exxon/Mobil, the only thing that might be worse was an 806 gasser. But Still a very good looking tractor
