Farmall A Drawbar Extension
John P.
04-19-2008 20:50:22
What is the real purpose for that triangular shaped drawbar extension?
tmonton
04-22-2008 05:35:50
 Re: Farmall A Drawbar Extension in reply to John P., 04-19-2008 20:50:22
The only time we used the bolt on extension was when baling hay.
Considering that the baler places a lot of rocking impact into and away from the tractor when running.
The extension hitched your implement tighter to the tractor and saved a lot of abuse to the swinging draw bar.
John P.
04-20-2008 06:40:52
Thanks for the replies! If using it for PTO work, would you mount the extension towards the left side of the drawbar to line up the PTO even though the implement would be off center from the tractor?
Greg-N-CA
04-20-2008 06:48:33
 Re: Farmall A Drawbar Extension in reply to John P., 04-20-2008 06:40:52
My SA is missing the extension, could you post a picture? I'd like to see what I'm missing, thanks.
John P.
04-20-2008 08:58:18
 Re: Farmall A Drawbar Extension in reply to Greg-N-CA, 04-20-2008 06:48:33
Here is a link to an item on eBay right now. Mine is a little different as I only have 1 row of holes on the tractor end.
http://cgi.ebay.com/Farmall-fast-hitch-fasthitch-2-pt-drawbar-extension_W0QQitemZ230242602548QQihZ013QQcategoryZ63988QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Lowell T
04-20-2008 04:48:08
It is used for PTO work with trailing implements.
It's needed to get right distant between the drawbar
hitch point and the PTO shaft.
tn terry t
04-19-2008 21:09:17
 Re: Farmall A Drawbar Extension in reply to Gary,kansas, 04-19-2008 20:50:22
with that plate you can turn a lot sharper with a trailer and what not i use the plate for our old hayrake its just long enuff that rake cant "jack knife and hit the rear tractor tire
