560 fast hitch
acdave
04-20-2008 07:50:00
i would like to take my fast hitch off and replace it with a straght drawbar does anyone know where i can find a drawbar for my 560 and would anyone be interested in my fast hitch thanks David
acdave
04-20-2008 14:36:42
 Re: 560 fast hitch in reply to acdave, 04-20-2008 07:50:00
yes i am having problems with the control valve and since i only use the tractor for haymaking and pulling the sprayer i thought i would just go with a standard drawbar and save another repair bill thanks for the info guys
CNKS
04-20-2008 13:34:32
U drawbars will fit anything from the C thru 560 and probably higher. Thicknesses are different, swinging parts for the H-460 are different from the M-560. Not absolutely positive that the swinger from an M will fit a 560, though.
Wardner
04-20-2008 12:31:06
I'll make the trade. Where are you located?
migraine
04-20-2008 08:23:51
Do you not like the fast hitch or does it not work properly? Most people are thinking of going the other way as you so should not have any problems finding a switch. A drawbar off of M series and 400 and 450 should all be the same as well as 460 and 560.
Zach Bouchard
04-20-2008 09:58:38
 Re: 560 fast hitch in reply to migraine, 04-20-2008 08:23:51
Have you seen the IH tractors over at Scholtens? Theres also the 1066 that was over at Meridian, It is for sale behind wecu. I heard you talking about buying that one. Did you?
migraine
04-20-2008 15:47:13
 Re: 560 fast hitch in reply to Zach Bouchard, 04-20-2008 09:58:38
No the ones I've seen are a little rich for my tractor account. Tractor that was bought at Meridian for 6700 now is asking price of 9800.
jal-SD
04-20-2008 08:15:34
I think that any drawbar off of a 450, 400, SM or M should work if you get all the mounting hardware. (My $0.02 worth. jal-SD)
