Ok heres the new update, Just got in the house from trying the MD again. With another bettery still won't kick. I moved the diesel side so it is completely shut off now atleast the smoke is gone, but the tractor won't even kick now. pulled on plug and it was dry as can be. not even a smell of gas on it. so now i am thinking its a fuel problem. i took the air intake pipe off, try starting it, couldn't really hear much of a sucking sound, until i put the choke on even then it didn't seem to pronounced. when i had the intake off i checked the carb and could blow through it with out a problem, and when the float was closed it stoped the flow like it should. What is tickling me is why it will shitch to gas no problem from diesel and why it runs SO good when it does finally run on gas Sometimes and i mean sometimes, like 6 times since i owned the tractor, it started on gas WITHOUT a hitch 2 turns of the motor. Whats with that!!! i'm sure they are all linked somehow, i know we will figure it out anyhoo Happy Farmin' Matt
