Farmall H trans stuck in gear
Rod Morris
04-20-2008 11:38:53
I need some help solving a transmission problem with my H. The clutch appears to work fine but it's stuck in gear. Any suggestions will be appreciated. Thanx
Farmall Freak #1
04-20-2008 16:54:43
 Re: Farmall H trans stuck in gear in reply to Rod Morris, 04-20-2008 11:38:53
What I would do is pull the pin on the shifter and take it out. When you look in there you will see where the shifter engages the forks. Two of them will be even and one will be in the gear you are stuck in. Stick a prybar in there and pry it bak to neutral. This happens to me on my M and 300 and this works for me.
Rod Morris
04-20-2008 17:20:05
 Re: Farmall H trans stuck in gear in reply to Farmall Freak #1, 04-20-2008 16:54:43
Thanx
HAS
04-20-2008 11:46:19
Ours does that too. Sometimes you can rock it back & forth by pushing by hand on the rear tire and get it loose. You really need to pull the shift lever, build it up with weld and then grind it back smooth. It has worn too short to engage the shift rails. If yo do a search on here you will even see some pictues of how is supposed to look when you are done.
Rod Morris
04-20-2008 13:35:10
 Re: Farmall H trans stuck in gear in reply to HAS, 04-20-2008 11:46:19
Thanx for the info.
