Need more help w/ 140 belt pulley
orangepower
04-20-2008 12:23:35
I got everything installed and when I engaged it, it made a whining sound. Could the gear from the drive shaft not be meshing correctly with the gear inside the pulley housing? The donor tractor I got the drive assembly from had one shim between the housings so I put it back on my tractor that way. I see there is a bearing out on the end of the shaft where the actual pulley attaches. Maybe it could be worn enough to be noisy? How do I get this bearing out? Thanks for any advice and help.
Haas
04-20-2008 18:06:40
 Re: Need more help w/ 140 belt pulley in reply to orangepower, 04-20-2008 12:23:35
If the shaft does not have play, the bearing is likely OK. I think some whine would be normal. If it is very loud, it may be the gear or the bearing. There are two bearings on the belt pulley shaft. The one nearest the pulley will come out once the bearing retainer cap/seal holder is off but it may be hard to get it to come out. I don't know if it is pressed in there or not. To get the other bearing out, you will have to remove the shaft which requires removing the pressed in plug that is in the housing on the side opposite the pulley. I'd try adjusting the gear lash before I messed with the bearings unless you have shaft play. You need to get a manual that tells you how to adjust the gear lash.
Hugh MacKay
04-20-2008 18:02:11
orange power: Just because it had one shim in the doner tractor, doesn't necessarily mean one shim is right for your tractor. Through the fill plug hole you should be able to see the right angle gears. IT calls for heels of gears to be in register with one another, and back lash between 0,004 and 0.006. Best gauge for that is piece of pop or beer can wall into the gear mesh.
The actual pulley shaft has two bearings, and the unit will have to be removed from tractor for rebuild. The whine is very likely bearings, however I'd check the gears first, they can whine too it not meshing correctly.
