serial number restore
stampmaint1
04-20-2008 14:54:13
third party image
Hi"
I am restoring a Farmall 1206. My serial number tag is beat up some. The power steering lines had been patched over that tag and the patch rubbed the paint off. I am looking for opinons on restoring this tag. thanks.
ScottyHOMEy
04-22-2008 22:13:00
 Re: serial number restore in reply to stampmaint1, 04-20-2008 14:54:13
There are those around that will flame me for saying so, but I'm in favor of doing anything you can to save an original serial number tag. You or I can send off to any number of sources for a tag that says anything we ask them to put on it, which defeats the whole notion behind those numbers. A horrible world could be filled with competing Farmalls with a serial number of 501 in a given model.
To your question, if your tag is silk-screened, ignore everything I have to say.
On my older tractors, a BN and a SuperC, the "silver" lettering and the blank pads for the serial number and max no-load RPMs were raised. I first scoured them down with a ScotchBrite pad. After masking off the pads for the serial number and the RPMs (and the whole tag from the surrounding area), I then hit the whole tag with a black lacquer. The next step was to wet-sand the black down to the level of the raised lettering, then clear lacquer over the whole tag.
It takes some work and patience, but comes back nicely.
BUT, it worked only because of the way the tag was made. Look yours over closely. It's altogether possible that the design/manufacture of the tags changed between the letter series I have and your 1206. If, as BermudaKen said, yours is silk-screened instead of being raised metal this WON'T work!
bermuda ken
04-21-2008 06:03:46
Contact Bob Diener at Morgantown, WV (304-599-4027)for a new tag. He has the best quality IH tags made.
The ink on the OEM tags is easily wiped off as it is only silk-screened on the metal.....poor quality finish.
stampmaint1
04-20-2008 15:45:13
This is a picture of my tag. I did not see one like it on OEM's site. thanks
Owen Aaland
04-20-2008 15:20:49
stampmaint1 said: (quoted from post at 14:54:13 04/20/08) Hi"
Most likely the steering lines were spliced to make it easier to split the tractor. Those lines can be a bit of trouble to get off and on otherwise.
