Re: Farmall H engine question...opinions needed.
kfox
04-20-2008 15:15:26
That cover for the valve lifters/pushrods has copper washers under the bolt heads. That may be the only problem. Most I have seen have never been replaced since the tractor left the factory. There is also a breather filter for the crankcase under the pipe attached to the cover. Most of these are plugged solid. A "Brawney" stainless steel scratch pad makes a good replacement filter.
ken
