IH 484 oil pressure
Michael price
04-20-2008 15:44:53
I drove the 484 around today and after it was good and hot the oil pressure dropped down to 10psi at idle, is this normal? Its up around 40 at higher rpms and 60 when cold.
JimB2
04-20-2008 16:08:11
 Re: IH 484 oil pressure in reply to Michael price, 04-20-2008 15:44:53
Michael, my brother's 454 only has a gauge with Red and White on it and with 15W-40 oil it will go to 3/4 white when cold and when warm between 1/2 and 3/4 and at idle at about 1/4 gauge.
How is your 484 starting now? Running smoother?
Did the leaks at the injectors stop?
JimB
Michael price
04-20-2008 19:58:19
 Re: IH 484 oil pressure in reply to JimB2, 04-20-2008 16:08:11
It ran alot better today, the leaks at the injectors seem to be gone. At the center injector about every 20 seconds a tiny bubble will pop up.
Still starts hard but I think I may need bigger battery cables.
