cleaning up supe h axle bearings
Andrew Kappers
04-20-2008 20:13:20
I unbolted the rear axles out of the super h the other night and wanted to clean inside the axle housing and cleanup the bearings. Is there a special way of doing this. Thanks
Roger46
04-21-2008 16:51:43
 Re: cleaning up supe h axle bearings in reply to Andrew Kappers, 04-20-2008 20:13:20
I assume you mean you unbolted the flanges on the outside of the axle at the wheels. The only way I know of cleaning the inside of the axle housing is to pull the axle. This requires taking off the bull gear inside the transmission, however. I usually take off the whole axle housing, pull the axle, and pressure wash the inside to get all the grease out. Roger
