replacing oil seal in super h rear end
Andrew Kappers
04-20-2008 20:17:40
I am trying to get off the little special nut that attaches to the linkage piece that drives the belly pump on a stage 1 super h. I shoved a rode between the transmission gears and tried to turn it off. I tried both ways and it wont budge. Over the years the oil seal went bad and sprayed rear end fluid all over belly pump reservoir. I am trying to replace the oil seal and ran out of ideas. Any suggestions. Thanks
Bob M
04-21-2008 05:43:16
 Re: replacing oil seal in super h rear end in reply to Andrew Kappers, 04-20-2008 20:17:40
Once that countershaft nut gets broken free it usually spins off easily by hand. Getting it broke free seems always to be a problem! A couple things that have worked for me. (Presumes you already locking the transmission gears…):
1 – Grab the nut with the biggest pipe wrench that can fit up in the belly and get a good bite on the nut. Some “strong arm” applied to the wrench handle will then break it free.
2 – Find a piece of square keystock that fits in the nut slot and is about 8” long. Lay one end of the keystock in the slot then give the free end a whack with a large hammer.
Here’s another I’ve heard about but not tried: Weld a piece of keystock to a large (eg. 1-1/4”) hex nut. Place the keystock end of the welded nut/keystock into the slot, then use an impact on the nut to loosen the countershaft nut.
Note! When reassembling the countershaft nut you only need to run it up hand tight – first time you use the belly pump the nut will tighten itself that last 1/16 turn or so!
Wayne in MN
04-20-2008 20:52:54
The coupling nut loosens by turning left (counterclockwise). Lock the brakes & put the transmission in reverse before trying to loosen the nut. It is tight because as the Lift-All is used, the nut is forced tighter each time due to rotation of the shaft.
Be patient and get a bigger wrench!
