Ref: Got to brag a little (Larry in Co.
Greasy John
04-21-2008 09:38:22
Had my bearing job done before I read your post(and all the other helpful text).I would only add that I used 2 old 5/8" x 8" long bolts-cut off the heads and screwed them in the top 2 holes .Slipped the axle and housing out and wrestled it to the bench .When I put it back with new bearings I just slipped back till it touched the bullgear =turned it a bit -went right together by raising the outer end a bit. Yours was a great post.tnx gentlemen John
Larry in CO
04-21-2008 18:30:25
 Re: Ref: Got to brag a little (Larry in Co. in reply to Greasy John, 04-21-2008 09:38:22
Thanks for the kind words. I put that out there in hopes that it would help somebody else along the way.Thanks goodness I haven"t had to do that again as some of those parts are pretty heavy for a 150# old man. Larry
