784 coolant
7lazy77
04-21-2008 13:32:50
I want to flush out my radiator & replace the coolant. I was told that I do not want to use ANY vehicle coolant, so I was just was wondering what kind to replace it with? Thanks
Gleanerguy
04-21-2008 14:09:24
 Re: 784 coolant in reply to 7lazy77, 04-21-2008 13:32:50
I have a coolant filter installed in my 684 to prevent cavitation, since its a wet sleeve engine.
You might want to consider installing a coolant filter as all wet sleeve engines are subject cavitation after they get a bunch of hours on them. It is important to use distilled water when mixing your antifreeze, other than that, just about any type of common vehicle antifreeze will work.
