Half shielded outer axle bearing-which way?
Randy-IA
04-21-2008 17:28:19
Hi All , The old ones had the shield towards the inside which didn't allow any oil to the bearing . But I grease the axles every other time I use it so they were well greased . I'm putting new ones in and want to make sure that's the way they are supposed to be . I just ordered the last six bearings ( both axles and differential ) today so it MIGHT be up and running this weekend . ...Randy
D Slater
04-21-2008 18:08:56
 Re: Half shielded outer axle bearing-which way? in reply to Randy-IA, 04-21-2008 17:28:19
Shielded side toward bull gear.
Randy-IA
04-22-2008 19:02:12
 Re: Half shielded outer axle bearing-which way? in reply to D Slater, 04-21-2008 18:08:56
Thanks ! That's the way the old ones were so I'll put the new ones in the same . ...Randy
