Setting points on an M
fastdzl
04-22-2008 10:34:06
It pains me to ask for help on this subject, but I'm at a stand still. My M was running rough so I thought this would be a good time to replace the points and condenser since the tractor is new to me. I removed the breaker plate from the distributor and started to replace parts.
Now for the trouble....After I disconnected the points and condenser and started to reassemble, I cant get the metal band spring on the moving point to hook up again. It physically looks impossible, but the new points are the same as the old ones.
Does anyone have any pictures or diagrams that I could look at while trying to put this thing back together, or maybe even some helpful tips? I apologize for sounding like an idiot, but this is my first experience with points.
Thanks
fastdzl
04-22-2008 17:43:03
 Re: Setting points on an M in reply to fastdzl, 04-22-2008 10:34:06
A picture is worth a thousand words. Thank you for posting that.
I'm not sure why I removed the breaker plate, but it's all assembled in the tractor again. Thanks for the help.
usetabesteve
04-22-2008 13:47:44
I am wondering why you took the breaker plate out. It's certainly not necessary, and you can see that it doesn't help anything either.
You put the screws in the part of the points set that hold it to the breaker plate first and partially tighten them. This keeps things from moving around quite as much. Some spring bands have a slot and others have a hole, but you put the spring on the threaded post and hold it while you start the nut. You hold it with anything you have available (thumb, screwdriver, needle-nosed pliers). If there are wires that go on the same threaded post, you can clip the end of the connector on the end of the wire to make it slotted. That way you don't have to hold too many bits in place at once.
glennster
04-22-2008 13:10:52
here is a pic of the inside of the distributor. you dont need to remove the breaker plate to change the points or condenser.
third party image
